08rdskeeter
- Joined
- May 13, 2010
- 3
Guys,
I need help. I have a Minn-Kota 4 bank battery charger and the other day we got back from a fishing trip and plugged it in like we always do, two of the lights on the charger were glowing red. I got to looking closer and it said check connection. I found out that 4 of the fuses were blown?? I tried to replace the fuses but they kept blowing? I decided to undo all of the wiring and take each battery out to check them as well as clean all the connections thinking this would help and it didn't? Then we got a volt meter and plugged the charger in and noticed that the polarity on the 1 and 4 wires was switched( the white wire was negative and the black wire was positive? The other 2 and 3 wires were the opposite? I tried calling Minn-Kota and they didn't really know what to say except it sounded like it was messed up and b/c we bought the boat second hand the Warranty was void. When you check the voltage coming out of the charger the 1 and 4 is running about 6.8 or so and the 2 and 3 is running around 3.4 or so. I don't know what to think or do now? Has anyone else ever ran into this problem?
Thanks
Thanks
