firecapt13
Thread starter- Joined
- Mar 13, 2010
- 57
1992 Wellcraft Mercruiser 4.3 Alpha 1 Gen II.
After all my work took it to lake today for test run and i have a vibration under load. I have replace gimbal bearing and u joints looked fine and greased them. They felt smooth with no stiffness. There is no vibration when I idle up to 4000, only when I take off and put in under load. It appears to be constant but a little worse under higher rpms.
The prop is a 4 blade plastic prop with a slight knick in one blade. It has some adjustment marks on it but know nothing about this prop.
What are some things that would cause a load vibration, If it were ujoints wouldnt they vibrate when you throttle up with no load?
