lower unit fluid
vip215dl
I have a 1998 vip deckliner with a 350 mag and a bravo 1 lower unit. I was told that on the tilt and trim i can use transmission fluid. Is this ok to mix tilt and trim fluid with tranny fluid? I didn't have any trim fluid the last time at the lake and he had a quart of tranny fluid so we went ahead and used it. Everything is working, just think i need to drain it and replace the fluid. It was low due to a leak in the plastic bottle....
Bt Doctur
Re: lower unit fluid
If you actually mean the plastic res. for the power trim, ATF is ok.
If you mean the drive oil res. ,it`s not OK. Losing that oil means there is a leak in the drive that need to be fixed.
vip215dl
yea, it's for the power trim... If i change the power trim res., will i need to bleed the lines somehow? thanks,,,
Bt Doctur
Just refill the res. system is self bleeding
vip215dl
thanks. would you know about how much this thing will cost? is it just the res. or the whole assembly?
Bt Doctur
ARCO sell them, the single screw from the bottom:ARC M525,the newer 4 screw :ARC 532
