coolguy982
Thread starter- Joined
- May 13, 2010
- 22
I'm new to boating and am learning as I go. Any help would be MUCH appreciated!
I just purchased a 1987 Thundercraft Citation 170 boat with a 4.3L OMC Cobra i/o motor. The boat is in great shape and was garaged its whole life. I've owned the boat for about a month now and have taken it out on the water a few times. If the boat sits for a week or so without being run, it has a very hard time starting up.
I just tried to start it tonight, and here's what happened:
1. I checked the battery. It was sitting right at 13 volts.
2. We hooked up the muffs, and started the motor. It cranked and turned over once, then died.
3. I tried to "pump" the motor as I read on some posts on this forum by moving the throttle back and forth a few times with the engine off. Tried to start it again and it cranked but wouldn't turn over.
4. Removed flame arrestor, opened butterfly valve with a screwdriver and sprayed starter fluid into the carb. Tried to start again, still cranked but wouldn't turn over.
5. Bro-in-law tried manually adjusting the throttle on the engine while I was cranking. Same results. To my knowledge, I don't think there is a way to increase the throttle while in neutral or choke the engine from the driver control panel (I don't see any choke buttons and I can't push the throttle forward or backwards without engaging it into gear first).
6. Measured battery again, now at 12.5 volts. Measured battery while cranking engine--10 volts.
7. Connected battery from truck via jumper cables thinking battery may be too low now. Tried to start, still cranked but wouldn't turn over, although it did sound like there was a little more power. Kept battery jumpered in for a while, then disconnected.
8. Tried to start again, this time while Bro-in-law pushed the butterfly valve in the carb open and closed repeatedly. The engine started to fire. It died a couple times, but then started up on the third or fourth. Bro-in-law was opening/closing butterfly repeatedly (maybe opening/closing twice per second).
We let the engine run for a while, engaged it in forward and reverse without problem, and then turned it back off. Tried starting it again and it started immediately. Did this about 4 more times and each time it started immediately.
Since it started up wonderfully while the engine was hot, we don't think the problem is the battery or plugs, or electrical for that matter. I don't see a choke button anywhere, so I'm guessing there is an electric choke somewhere? Since the engine wouldn't start until we opened/closed the butterfly valve repeatedly, does that mean some sort of air intake issue? As you can see in the photos below, the flame arrestor does have some oil buildup on the outside of it. Could this hinder with the air intake?
A couple other notes:
1. The butterfly valve was closed when engine was cold and does appear to be opening/closing properly when the engine is running.
2. The previous owner said that they would have to take off the flame arrestor and spray starter fluid down into the carb at the beginning of each season. That's why we tried #4 above.
3. We had this same problem the last time we took the boat out, but Bro-in-law that time toyed with the throttle on the engine by manually moving it in and out. We also had the butterfly open and had sprayed starter fluid down it.
4. Not sure if this is related or not, but after we finally got the engine started tonight, when I revved it up to 2000-2500 rpm and then put it back in neutral, the idle was at around 1600 rpm. Before revving it up (and just after starting), the idle speed was only about 950 rpm. It seemed that the throttle cable wasn't getting pushed all the way back when releasing the throttle. To fix this, we disconnected the red cable head in the third picture and turned it a few times. This seemed to do the trick and after doing this and revving it up to 2000+ rpm and back to neutral, it stayed at 950 rpm at idle.
Sorry for the long post, but I wanted to make sure I didn't forget anything.
Now, any ideas as to why the boat is having trouble cold starting?
Pictures of the engine are shown below:
