quantumman29
Thread starter- Joined
- Jul 15, 2004
- 105
my engine starts fine in the morning,after I make a long run it is hard to start again,and I always need to prime the bulb when I want to start it,
when the engine does start again,it dies when throttles up,it dosent rev up in neutral and I need to wait for about 5-10 mins of idling before it will rev up and go on plane,
there is always a bad gas smell,and the carbureators are all dripping gas when the engine is not running,
the engine runs great once it gets going again,hits wot at 5800 rpm,then it just begins to loose power like a fuel shortage, when i slow down it stalls and smells like gas.
it will start up again but wont rev up past 3000 rpms,if i wait an hour,the engine starts right up,runs great at wot for as long as i need to go,then it all happens again,
the engine never starts without needing the primer bulb primed,and it never runs great 2 times in a row.
does this sound like gummed up carbs?
also is it normal for water to be running along the spark plugs while its idling?
thanx,
mike
thanx,
mike
