need help asap
peugeot
hi i need help with my 25hp yamaha 2 stroke engine.da bottom unit is leakn a bit of oil out.when i checked the oil in the gearbox it is white in colour and think it should be red???
99yam40
Re: need help asap
You have water getting into it and you need to find out where.
Drain the fluid out to get the water away from the bearings and gears. and pressure check the unit to see if it is from the prop shaft seals, drive shaft seals, shift link seal, or drain/fill screws.
you may have to pull unit and replace all just to make sure.
Do not let the watery oil stay in the unit foe long.
peugeot
Re: need help asap
the oil is kinda milky in it.and its coming out beside a bolt where u join it bak up to the middle section
stylesabu
Re: need help asap
can you get a picture? you have water getting in.you need to figure out where its getting in, like previous post its one of 3 spots unless there is a crack in the case
