can i turn my plastic tank into a dual line pressure tank
1961glastron
just wondering if i can turn a single line plastic tank into a dual line prsseure tank,,,,can i insert an air fitting or will the tank blow apart,,,i was just wondering cause it is $115 to get my tank redone...the plastic tank does have a vent screw on it and i think as long as i get done driving it or am gonna fish one spot for awhile then as long as i open the vent up i think it should be fine....my tank also has the bulb to prime the line
jdsgrog
Re: can i turn my plastic tank into a dual line pressure tank
Short answer, no. Which motor do you have? You should be able to convert your motor to take on a fuel pump.
Mas
Seems to me that $115 is not worth a possible gas leak or worse out on the water. I'm not saying it cannot be done...just that I would not do it. Pressurizing plastic on purpose just does not sound good. Some would even go as far as saying the dual line pressure tanks are a high safety risk at best...others will disagree however.
You can find a working tank for $50 or less if you look. Post a "wanted to buy" on Craigslist.
What needs to be fix on your old tank? Gaskets and o-rings for the dual line tanks do not add up to $115.
Mas
plastic tank, NO!!!
depending on which motor you have, it will cost $115 to convert, or buy a 2 line tank.
cajuncook1
That's a bit dangerous....kind of like playing with dynamite!!
1946Zephyr
If you need gaskets and stuff for your old pressure tank, give Doug a call at Vintage Outboard. He sells kits for those tanks. 509-747-9960:cool:
I posted a want ad on Craigslist and found a dual line tank for $10, which is a great deal, especially since I got a good working one for that.
tx1961whaler
No way on the plastic.
Ever leave one of those tanks in the sun with the vent closed? :eek:
1961glastron
well i know it can be done but then again if i ever forgot to vent the tank then it would be a time bomb,,lol,,,,but anyway i need everything,,,my fuel pump is crap,,,then gasket,and new line too but the bad thing is ,as i am missing the $75 dollar connector too,,,which i dont need really anyway,,,,also i am running an evinrude big twin 30hp
CATransplant
Cheapest way to go is to install a fuel pump on your Big Twin, then buy a cheaper non-pressurized tank.
Or, you can hunt around for a good pressure tank with all the trimmings. There are always some around for sale.
Don't try to second-guess this stuff. Gasoline is dangerous. Do it right or don't go boating.
Tim Frank
well i know it can be done but ....
Not sure why you asked then....:confused:
Of course you CAN do it....the advice you are getting (good advice) is that it is a really bad idea.
jay_merrill
You can light a match in a room full of propane too. I suggest that you don't.
wilde1j
The pressure tank I gave a link to still has 30 minutes and no bids ... $50 is hard to beat!
Only one bid and went for 49.95 ... somebody got a deal!
