1983 Johnson 235hp broken starter mount
ToddSearle
The mounts on the the intake manifold that the starter bolts to broke. I have heard that it can be welded, I have also heard that it can be repaired by other means. Does anyone know how I can fix this?
emdsapmgr
Re: 1983 Johnson 235hp broken starter mount
If it's the intake manifold that is damaged, you may find it easiest to just replace the mainifold. It is just a bolt-on piece. The V6 mainifolds are generally all the same, with some having the recirculation systems on them. There should be plenty of used ones around in marine salvage yards.
ToddSearle
Thank you for your reply. Everyone seems to think that I should repair it. Replacing it may be a little pricyI would think, but should give some piece of mind. Thanks again.
ToddSearle
It actually is the cylinder crankcase assembly that is broken. I looked at it a little better. Can this be repaired?
ToddSearle
Would JB Marine Weld be an option for this repair? I don't know what kind of torque the starter puts on the cylinder crankcase assembly what it engages.
wilde1j
Forget JB Weld ... it won't hold. Get a used manifold or get it TIG welded.
Salvage yards:
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
Superior Marine (800-338-9281)
trixieslanding.com Trixie?s Landing, Bayville, NJ 732-269-5838
americanoutboard.com
piratemarinesalvage.com/
ToddSearle
I have had two welders look at it and they say that welding it won't work. So I am looking for an alternative.
wilde1j
Already gave you the alternative ... buy a used one! See list above.
ToddSearle
Thank you very much for the list and your help. It is greatly appreciated.
