2003 90 hp 2 stroke starting issues
franger
that time of year to get the boat running again and this is first time it wouldn't start. removed plastic flywheel cover and when trying to turn over found the starter pinion spinning but not meshing with the flywheel. any thoughts?
thanks in advance, frank
franger
Re: 2003 90 hp 2 stroke starting issues
any input appreciated as i may have to take it to the dealer this week and would like to try to attempt the repair myself, especially if it only requires changing out the starter motor
CharlieB
Starter drive is 'screwed' up the shaft by the sudden speed of the starter motor.
Often the cause of a 'slow' starter is;
Low Battery, charge it fully
Poor connection on a battery cable, clean BOTH ends of both cables, also clean the ends of the starter to starter relay cable
Poor brush/armature connection inside the starter, disassemble starter, clean, brighten commutator, lube starter bushings, replace brushes if worn short.
Poor connection inside the starter relay, test by using one side of battery jumper cables, connect to battery side or directly to battery, strike other end to other side or directly to starter terminal, if starter turns to speed replace the relay.
franger
will try your suggestions and report back, thanks
