Going Forward in Reverse!!!!
hardsoko
Not sure if I am in the correct forum for this question but here it goes. I have a 1982 Johnson Twin cylinder 60hp outboard. I just replaced the lower unit on this motor. I was told my replacement unit was off a 1976 55hp Johnson it has the larger gear case 4 1/8". This unit came with no prop so i bought a used 14 x 13 prop for it, My old prop would not fit because my old lower unit was a standard size. Now after a few days of getting the motor running and mounting the new lower unit i load up the wife and kids and we go to the lake to test her out. Get the boat in the water put the controller in reverse to pull out of the launch and the boat goes....... FORWARD!!!!! put in in forward and it goes in reverse. now first thing i thought was i have the wrong rotation prop. So after tooling around at a top speed of 7mph in reverse but going forward we load up the boat and head for home. I have compared the new prop to my old prop and they are the same rotation so thats not my problem. I am thinking it might be something in my lower unit causing it to rotate the wrong way I do not know much about this other lower unit just what i was told it came off off and that is a commercial grade. would a left rotation prop be what i need or is there some way i hooked up something wrong?
hardsoko
Re: Going Forward in Reverse!!!!
After rotating my flywheel clockwise "the way it turns when it runs" the prop shaft is turning counter clockwise so i am assuming this is a counter rotation lower. any other way of telling or do i just need to pony up and buy another prop and send a "kind" letter to the seller of my unit for not telling me it was a counter unit. thanks guys
rjwoodrome
So is there any way to return it at all or did you have to special order it? did the vendor supply the order number ? seems if he did he-they specked the order numbers then there should be a no charge exchange...
hardsoko
no i purchased the unit on ebay. I dont have any problems with the unit it seems to shift fine and there are no leaks. I sent an email to the seller asking him if he knew that this was a counter rotation unit. He wrote back saying that that it was off a single engine setup. The prop that was on it was a right rotation 11 3/4 x 17 Michigan Wheel 012039. Is it possible that my motor is turning the wrong direction? or my shift cables got messed up? All that has been done to the motor is i have cleaned the carbs (one float was stuck and dumping fuel into the cylinder flooding the motor. A i put new plugs and wires on it. And of course put the new lower unit on it. Everything bolted on fine, shift linkage lined up fine. So if this is a standard rotation model as the seller assures me it is what would make it rotate incorrectly?
mikesea
You would get more advice on the OMC/evinrude johnson forum.There were a couple years that the linkages were reversed ,I think you replaced the lower with one that operates with the push /pull vs the pull push.I know I read about another guy with that problem on the omc forum whithin last month.You might be able to search the site somehow and see if his problem was fixed,and how
timrod
If it all works fine ,then change you shifter around and it will work like always .Just take it and reverse it 15mins top.
