wabbit1211
- Joined
- Apr 17, 2010
- 2
I have 3 outboards all with the same problem. An evinrude 115 hp I think it is a late 70's model maybe early 80's And A 115 Johnson and 140 hp johnson All Are about the same age but not sure of year models on any of them. All have the same Carbs elegtronics are all close to the same, Very little differences in any of them. The problem is none will Idle, and only will start by moving the throttle forward. they all die when you move the throttle back to idle position, or when you try to put them in gear. All plugs are new and all are firing, I have disassembled all the carbs, cleaned all parts and reassembled them. I was an automechanic for years but boats just seem to throw you for a loop. I have read every post remotely pretaining to this and tryed to adjust them every way I can see to adjust them, but I'm bound to be doing something wrong. Compression on all three engines are all almost exactly equal( about 95 lbs) buy my gage, all gages I know can vary but I used the same one for all. If you can get any one of them into gear and give them throttle, they will all reveup and seem to run fine, plenty of power and no misses, but if you bring them back to idle or to neutral they will die. All will restart as long as you move the throttle up past an idle with no problem. What exactly adjust the idle? IS it the screw with the rubber stop ont the arm on the side of the motor or do you do it with the cable? What can I be missing since I can't get anyone of the the motors to idle. I'm at witts end someone please tell me how to adjust the idle, pictures of what to adjust would be helpful. Could timeing be off on all three, seems odd that it would happen to all three. All have fresh properly mixed fuel too and all screens cleaned no fuel leaks. All help will be greatly apreciated. Thanks Harold
