1) Performance issue you are trying to correct.
Run it up to top end on the original 14 in, 21 pitch prop and it does 33 mph on gps, 3800 RPM.
swap prop for a 4 blade 18 pitch, and it does 32 mph on gps, 3900 RPM
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
21P- Volvo, 18P- Michigan Wheel Vortex
3) Current prop diameter and pitch (required).
above
4) Wide open throttle RPM and speed with an average load (very helpful)
above
5) Engine/drive make, model, year, and HP
2008 volvo penta 3.0 135 brand new
6) Boat make model, year, length and weight
2008 Glastron 175, around 2100lbs? bought brand new couple of months ago as a boat that had been setting around for too long...
not really worried about the top end, just wondering if there is some horsepower left on the table. With 18 pitch 4-blade, the boat planes effortlessly and at around 3 mph less than the 21p.
is the engine set up rich right off the floor for safety?
above
above
