bob johnson
- Joined
- Feb 25, 2009
- 4,306
been chasing this issue for a while and now after using as much diagnostics as i can so far...i have
1995 115 hp johnson v4
60 degree looper, eagle motor
OIS ignition
each head runs barely 120 degrees at idle..
installed new water pump and have great pressure
new thermostats a few months ago
10 lbs at idle
almost 30 lbs at 5000 rpms
I have a temperature guage monitoring each head.
I can cruise and one head goes up to about 140-150 degrees, the other heads satys close to 125
when i take the motor up to 5000 rpms( WOT now that i have the 17 pitch prop on.)
the one head goes to 180 degrees, while the other heads may run to 145 ish.
I throttle down and in less than 30 seconds the high head falls to 150 again...
if i go back to low rpm motoring ie about 2000 rpms, both heads fall back to about 125 degrees
the past two weekends i have used a high tech infared temp sensor to verify temps( they are matching my guages exactly!!)
so i believe I am getting good water flow across the block and head..
it reacts....but SOMETHING is making the head hotter than it should be.
My next planned experiement to is to test the temp sensors warning circuit..
a few questions:
1.)what could be causing the one head to be hotter?? a lean condition? is a piston rubbing?
2.) what can i do to fix it?
thanks
bob
OIS ignition
10 lbs at idle
a few questions:
thanks
bob
