1960 Johnson 10hp Impeller Change
dhughes214
Motor has been sittin, I'm gonna do the impeller tomorrow. The only other impeller I've changed was on a 69 evinrude 115. The evinrude had electric shift which was a pain (and it was huge), so I'm guessin this should be much easier. Any tips or tricks or things I should watch out for?
eavega
Re: 1960 Johnson 10hp Impeller Change
Impeller change is fairly straightforward with this motor; drop the LU, unscrew the impeller housing, line up the key, install new impeller, close it all up. The "Gotchas" that I remember:
1. Water tube can be a bit of a pain to line up.
2. Be careful when you re-attach the shift rod. make sure you have correctly lined up the bolt in the coupler, else you will strip the bolt after a while.
-E
dhughes214
Ok so how do disconnect the shift rod? The 69 rude 115 I did was electric shift so I didn't have to mess with the shift rod.
eavega
Small oval window on the leg. remove the two screws and plate. Inside will be a brass coupler with two bolts. Remove the bottom bolt, and the shift shaft down to the gearcase should slip out. You may have to coax it a little, but it will come on out.
-E
dhughes214
sweet got it. Hey how do I know which way to bend the impeller to make it fit in the water pump?
AlTn
the driveshaft turns in a cw rotation...the impeller vanes will "flip" to the proper rotation regardless how you install it...anyway, the vanes should trail when the driveshaft is turning cw
Jellio
Another tip: there's a little tiny pin holding the impeller in place when you slide it on.........don't lose it trying to find a replacement is hell.
samo_ott
-E
The key here is to totally remove the bottom bolt/screw, don't just loosen it. It must be out and in your hand to release the shifter.
dhughes214
thanks guys. I got it off, and am picking up the new impeller on monday. Should be smooth sailin' from here.
