BassnKY
- Joined
- Jul 30, 2009
- 126
I have a problem with my 1984-85 Mercury 60 that I hope someone can help me with.
The last time I was out on the lake, all of a sudden, I lost power. It seemed like I only had it at half throttle.
Upon inspection, I found a couple of very small pieces of aluminum on the plug (NGK-BUHW - This plug has an electrode in the middle and no protruding grounding electrode) between the center electrode and the outer ring that was shorting out the plug. This was on the top cylinder. The first thing that went through my mind was a blown-up piston.
Next, I checked for compression. I have good compression in all 3 cylinders.
Next, I removed the intake and exhaust port covers. Upon inspection, I discovered a very small chip (Approximately 3/16" wide and 1/32" deep
- this is as close as I could measure with a dial caliper) in the ridge of the top piston.
After I discovered the chip, my next step was to look for a source of a piece of metal that could have caused the chip. I looked in the cylinders, intakes, exhaust, and lower end. The only thing I could find was 2 small areas in the intake cover where it appeared that the metal (Even though there was no corrosion) was trying to flake. but, I did not see any missing pieces.
Also, I checked out the cylinder wall and could not see any scratches. The only thing I could see was the normal wear patterns.
My only thoughts on the cause would be metal fatigue or running slightly lean caused the piston to get too hot.
Does anybody have any idea what could have caused this?
