78 merc lower unit
mc66
lower unit on 78 Merc, 20hp/200 is stuck. I believe the shaft is rusted together. Somone mentioned to take the power head off but if they are stuck together how is this done? Any ideas or suggestions? Thanks.:confused:
Jacket4life
Re: 78 merc lower unit
I read a thread on here about a guy hanging weight on the lower unit and spraying PB Blaster into it everyday and it eventually turned loose. He had a picture of it seems like it was suspended from a tree limb or a frame (I remember it was outside...) with a platform he made out of plywood chained to the lower unit and a couple hundred pounds of iron stacked on the platform. That's the only advice I've seen about it. I can't even remember the thread, don't know what to tell you to search for though.
mc66
Thanks Jacket4life. Where would I go about spraying the crank if I can't see it? Any way to access it? I don't know of any.
Wingedwheel
There was also a post on here awhile back with pics. The guy actually had to cut holes in the drive shaft cowling. He must have been good with a heli-arc though. In the end you couldn't tell. Anyway I believe he did this to get heat to the coupling to the powerhead.
mc66
wingedwheel i saw something about that no pic's can't get clamp off. do you know how? seloc ng need shop manual. i think round rubber mounts come out removed snap rings just now soaking one side at a time try tomorrow or drill sm hole between clamp and base spray and hope for the best thanks mc66
mc66
thanks for your suggestions hung it, beat it, cut it, and two cans of pb blaster nothing .about a month later walking by to get lawnmower gave it a grudge shot with a near by hammer a bam it came off bought another motor for parts and reassembled thanks again mc66
