Rebuilt the carbs late last year and am starting her up for the first time this year. Primer bulb gets firm after a few pumps. A couple days ago while testing, she was idling and a steady stream of gas was flowing out of the float bowl cover (out the hose that exist through the cowl). I took off the float bowl and adjusted all four floats to be parallel with the gasket when turned upside down. Started her up this afternoon after putting it all back together and she idled a bit - no leak.
However, she was stalling consistently after running for 10 seconds. After doing this start, idle 10 seconds, stall process for about a 5 minute period she started streaming gas at the float cover again. Any ideas what else may be causing the bowls to take in too much fuel?
Thanks in advance!
Thanks in advance!
