shane52501
- Joined
- May 17, 2010
- 14
I have a 1980 150hp Evinrude sport and I replaced the lower end today with a 1991 Johnson 150hp. The driveshaft and lower unit seemed to bolt up fine but I am having trouble with the Shift rod. I slipped it up and got it bolted into the rocker on the powerhead but when I shifted it into reverse it would jump back out while turning the prop by hand in reverse. All other gears worked fine. So I tore the lower end apart and realized the shift rod had got screwed out a little from the lower unit. I then screwed it in tight and bolted the lower end and shift rod back up, but now it will not even go into reverse. Any ideas?
