I picked up a near new 1973 merc 200 and after putting it in the water found it was running on one cylinder. Swapped the coils and spark followed the coils, so I figured it must be the one coil and ruled out the switchbox. So bought a new coil and installed and fired right up as it should when running on 2 cylinders. Shut it down and came back a few minutes later to start and started hard and I could immediately tell by the sound it was running on one cylinder again. So got my Harbor freight spark light out and had very weak and intermittant spark one the same cylinder that had the bad coil before. I guess I need a DVA adaptor to check peak voltage on the components but I am hoping one of you out there might have some insight on what I could check without a dva. This is my first experience with CDI as I have 5 restored old inline 6's and I know how to troulbleshoot points/dist ignition, but this is new territory for me.
Thanks Gary
Thanks Gary
