Keith Wilhite
- Joined
- May 19, 2010
- 3
I've got a problem with my 1996 Mercury 5.7L Thunderbolt V not wanting to fire. With the engine spinning, it seems to initially try and fire, but then won't. Oddly enough, when I toggle the ignition kill switch on & off, it seems to try to make the engine fire each time the switch is in the "on" position. Switch tests okay, so not that. Timing light on plug# 1 lights maybe once when trying to start, then not again. In the Mercruiser manual, under...
"Troubleshooting Thunderbolt V Ignition
Ignition Control Module / Coil / Distributor"
I've successfully made it as far as....
"Unplug WHT/
RED bullet connector
from Distributor.
Check for 12 volts
on lead coming
from module"
I have 0 volts on the lead coming from the mudule with key "on". Manual says replace the ICM. I just wondered if there's any better way to confirm a bad ICM before I purchase a mildly expensive new one. I've read that they normally do not go out unless wet or struck by lightning, neither is the case that I'm aware of. I've actually had this same basic problem for three years. On occasion, after running the engine under a load, it would die when returned to idle. I'd try and re-start and experience the exact same behavior as described above. However, after sitting for about 20 minutes or so it would always start right back up just fine. Won't start at all now. Appreciate any advice available. Thanks!
"Unplug WHT/
from Distributor.
Check for 12 volts
on lead coming
from module"
