cavitation
jelli
my cavatation plate sits 2 inches above bottom of hull is ther any fix besides geting new motor or cutting down transom
CATransplant
Re: cavitation
We need more information. What boat? What outboard? How is the outboard mounted on the transom? Photos would be good, too, if you can manage that.
jelli
Re: cavitation
boat is 15 foot chrysler with 20hp suzuki i dont know what u ment by how its mounted its got the hooks that go oner the transom
RL Gman
Re: cavitation
I think CA main point there is that we have no idea how to help that situation without looking at it. Take a few pictures of the transom, the mount and where the c plate is at in relation to the transom.
With the information you gave (even the second bit) all I could recommend at this point would be a jack plate, but I have a hinting suspicion that you have no desire to put that kind of money just to drop the engine a couple inches...;)
CATransplant
Re: cavitation
Some outboards are bolted on the transom, not clamped on. What is the outside measurement from the top of the transom to the bottom of the boat?
We can't see your boat, so you have to supply the information we need to help you. Without the measurements and other information, there's not a lot we can tell you.
jelli
Re: cavitation
from top of transom to bottom of boat is 21 inches c plate is 2.5 inches from bottom of boat sorry i cant giv pics but thanx for the help
RL Gman
Re: cavitation
Just out of curiosity...does the prop currently cavitate when given power?
Also, does the engine have any adjustments where the bolts go through the transome to lower? Basically, do the "hooks" you mention sit flat on the transom?
jelli
Re: cavitation
yes cavitates when at full throtle but only at 3/4 to full and yes hooks sit flush on top of transom
RL Gman
Re: cavitation
I'm guessing it has manual tilt on it...have you tried different tilt settings? Does it give the same response?
Although the more I hear, the more it sounds like that engine needs to be lowered...and I dont know many ways around that without digging into the transom, new engine, or jackplate...
CATransplant
Re: cavitation
That's a long transom boat, and you have a short shaft outboard. Unless you install a jack plate to lower the outboard or do a cutout for it in the transom, you'll continue to have the same problem.
Those are the options, aside from getting rid of your short shaft engine and getting a longshaft one.
jelli
Re: cavitation
k thanx for the help i really apreciate it any one know wher to get a cheap jack plate
RL Gman
Re: cavitation
I googled "jack plate for small outboard" and got all kinds of responses...
I even found another thread on iboats about it...do a quick search, start comparing prices.
