2000 150 johnson 6cyl 2 stroke. compression 90psi all cyls. good spark. rebuilt carbs, new filter, new vro pump. seperated from boat on 6 gal tank. running on hose spits quite a bit for a little while then bulb gets soft and dies like its not getting fuel. in water cranks runs at idle, put in gear and runs ok 1500rpm then throttle up and boggs/spits cant get on plane. reeds seem fine bc im not getting any fuel spitting out of carbs while on hose. floats are set right, carbs are cleean, mixture screws are set at 2 turns out, have played with them starting at 1 1/2 out and nothing seems to help. seems like its not getting fuel but i dont understand why....any ideas?
