engine bogging and poping truh carb ..
inchman
hi all, ive a 1988 bayliner trophy with a mercruiser 3.0 engine, the engine starts great and idles fine, but once i pass 3000 rpm ( aprox ) the engine hesitates and looses power and some times pops thru the top of the carb, has anybody any suggestions of what trouble shooting steps i should take ??
cheers Gary
Re: engine bogging and poping truh carb ..
Ayuh,... It's staving for Fuel...
Change the fuel Filters 1st,+ if that don't do it, find the restriction...
180shabah
+1 - find the fuel issue.
It's a 3.0, so probably no water seperator - you NEED one.
D
DJ
Guest
Possibly the anti siphon check valve at the fuel tank outlet. The valve is the tank outlet. It's ok to remove it FOR TESTING ONLY.
RickJ6956
Other possibilities include ignition timing and worn-out points.
6meter
Or coil, again.
inchman
hi, i did a few checks today, and im only getting 2.75 psi fuel delivered to the carb, when i spray a petrol, into the carb is seems to eliminate the problem, think is a fuel pump the answer to my problem.
cheers Gary
Ayuh,... Possibly, but the fuelpump can't push what it can't suck,...
Try a Test Tank like DJ said....
180shabah
cheers Gary
Why jump straight to the most expensive part and hope?
Filter?
AS valve?
Vent line clear?
Filter/s?
Collapsed fuel line(not likely but...)
