Wakesilver
Thread starter- Joined
- Jun 21, 2009
- 76
While troubleshooting an ignition problem for hours on an early 70's Mercruiser 140, I "let the smoke out" by hooking up coil minus/distributor lead to the solenoid and ballast wire. Most of the damage was the insulation heating up on the tan solenoid wire. I also saw a little puff at the distributor. After I shut the starter down and re-referred to the manual I realized the error of my ways. After wiring the coil correctly, the motor started instantly (less than one 'crank') and I idled for 10 minutes on the muffs.
Lessons learned:
1) Check the points first, not last (root cause)
2) Check the schematic one last time before applying power to the ignition system
3) The "stickies" are great reference materials...thanks!
My questions:
1) What might I have damaged with my wiring mess-up? Condenser?
2) How can I tell if the ballast wire is working? Coil + has 12.4 v before starting
3) How does one make a remote start switch?
Thanks!
Lessons learned:
My questions:
Thanks!
