If a power pack is bad???
crazy charlie
Does a bad power pack cause a motor to run crappy or does it not run at all?? Trying to troubleshoot my 95 150hp Ocean pro that has good compression in all 6 but is running rough and sounding like it is at 1/2 power.Charlie
countvlad
Re: If a power pack is bad???
if it runs i would start checking other things.... check spark, carburetors might be dirty, timing? we need more info.... what caused the motor to run crappy?
crazy charlie
Cant seem to figure why its running crappy.Ran like a champ on mmuffs in my driveway one day.The next day,it was struggling to stay running .Never even left the driveway.Checked compression which was 125 in all 6. Did a decarb.added new fuel and changed h20/fuel seperator.Carb filter had a few tiny particles but nothing of a clogging nature.I will replace it mif I can figure out how to remove it from the plastic housing.Charlie
countvlad
when were last time the carburetors rebuild? decarb helps but nothing compares with a rebuild.... check spark on all cylinders and spark gap... one of your coils might went bad... if you have spark you can move to fuel...
