89 Johnson 40 hp - Fuel Pump Question
Caddis295
I recently removed the VRO from my 40 hp Johnson. I was directed to purchase and install the Sierra 18-7352 fuel pump. The install was easy and now my motor will not idle longer than a few seconds.
My question is, should I have purchased the 3 Port Sierra 18-7353 fuel pump and attached the third hose to the pulse port originally for the VRO?
I say this because I think the fuel pump is not working.
Regards,
Caddis295
Caddis295
Re: 89 Johnson 40 hp - Fuel Pump Question
Someone has to know something about these fuel pumps.
Thanks,
Caddis295
18-7352 fuel pump, should work fine with your motor, sounds as if you have a low speed clogged jet. what are your idle rpms. did you plug the old pulse hose?
Caddis295
Tash,
The pulse line was plugged. I can prime the motor and it will idle for a short time then die.
I guess I need to take another look at the carbs.
Thanks,
Caddis295
