Need help on transom thickness!
thrillhouse700
I have been searching for transom thickness in the mercruiser manual and i am getting frustrated that I can't find it. I could have sworn that the transom thickness spec was 2-2 1/4"
I know I found it on a mercruiser website not the book. If anyone has this website please post up. thank you.
mrdjflores
Re: Need help on transom thickness!
I have seen it listed in a few resto threads from anywhere between 1-3/4" to 2-1/2"
thrillhouse700
Yeah, that's what I remember some numbers like that. But im trying to find the actual spec.
sprintst
I have a Mercury Mercruiser gasoline engines sterndrive installation manual for Alpha and Bravo that shows
I did 2 inches of wood 2- 3/4 inch plywood and 1/2 around the outdrive opening. The alum hull made up the rest.
Transom Thickness and Surface
IMPORTANT: Transom thickness and surface plane (flatness) must be controlled
where the sterndrive unit mounts.
Transom Specifications
Thickness Between 2 - 2-1/4 in. (51 - 57 mm) for 8 in. (203 mm) to either
side of the vertical centerline
Parallelism Inner and outer surfaces must be parallel within 1/8 in. (3 mm)
Flatness Transom surfaces in area where transom assembly will be
mounted (includes vertical as well as horizontal dimensions):
Inner Surface ? Flat within1/8 in. (3 mm)
Outer Surface ? Flat within1/16 in. (2 mm)
Angle 10 -16 Degrees
Here's a post that Don answered that had the link to the manual I have
http://forums.iboats.com/showthread.php?t=273543
thrillhouse700
YES!!!!!!! sprint your the man thats the exact thing I was looking for I had it saved on my computer then it needed a reformat. THANK YOU!!!!!!!!!!!!!!
sprintst
No problemo. Went through the whole thing myself one time. I know how frustrating it can be.
