FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: new to the boating thing just drained my gear oil.....
there are small passageways between upper and lower, oil can't flow downward properly, never makes it to lower, pressure from pumping from lower to upper means if you see oil coming out of top vent hole...passages must be full.
I filled mine from the bottome without a pump. It wasn't too bad with a helper. You just have to squeeze the jug and collapse it as best you can as you fill the drive. You have to keep topping off the jug because you can't get the last third of the jug to empty out.
Mine needed like 71 ounces to I had to use some out the third quart which made it somewhat easy to do.
Oh, and make sure you have someone to open and close the vent plug when swapping jugs or a lot of the fluid will drain out.
A DIY pump is less than $20. You will save that in cleaning materials and unspilled lube in 1 or 2 uses. Just get a pump, they have a threaded fitting that fits the bottom hole on the drive so very little gets spilled.
Just get the pump can be had at any marine store for around 10-20 bucks depending on which one you want. They screw right onto the bottle of lube and screw into fill hole, very easy and a must have. I would NOT be willing to roll the dice and try to do it from the top vent hole, just not worth the risk imo. Get the right equip and the right lube for your OD and learn how to do it then you will know from here on out and can save yourself a bunch of money in the future.
I didn't know you could get a pump until I found this thread. My local guy told me to get a weed pump when I asked them for one. I found this one below (as well as a few others)
Walmart has them along with the Quicksilver 90w oil you need. The pump cost just a few dollars and you can use it again next season. The right tool for the right job. Regards
Steve
