starting problems
DEFTONEchris
Hello,
My merc 1974 115hp 1150 suddenly will not fire. I had it running saturday for a few minutes, and nothing since then. It is getting fuel but I think it is a no spark issue. I sprayed some starter assist fluid in the engine and still nothing. That allways helps when it has been a while due to the notorious cold starting problems this engine has. Where should I start to look for my problem? Thanks to everybody for your reply.
chris
waynelk
Re: starting problems
If it wont fire with starting fluid probably no spark. Most likely spark controll box, but could be coil. Check for power to control box.
