shotgundexter
Thread starter- Joined
- May 24, 2010
- 24
I read a previous post, had great pics and info on this. The leak seems to be from the back of the block. I see from the pic there is a large freeze plug, and i realize it could be cracked. The engine starts and runs fine, but i do hear a little rattle from the flywheel area. 1- could this rattle be debris from the plug popping out or busting. 2- Is there anyway to slide the outdrive and bellhousing back, remove flywheel and replace plug- without removal of engine. 3- Would it actually be easier to just pull the motor.
engine is 3.0 mercruiser, with the Alpha 1 outdrive
