thequietman
Thread starter- Joined
- Jun 21, 2004
- 5
Way too much.
Like it drains out several ounces in my garage after a day fishing.
It loads up at idle, then cleans out and runs fabulous.
I have put over 500 hours on the motor with just lower end lube
changes every year or so, and new plugs each spring.
It starts instantly, hot or cold. Great motor.
But... using way too much oil suddenly, and when you prime it hard
with the bulb, gas leaks out of the top carb or black box thingy.
I'm not sure if that is normal or related.
I am tempted to simply block the oil line like many do, but this boat has
ran perfectly for 6 years and almost 3,000 miles with zero, zip nada problems
and less than (way less) $100 in maintenance costs, so I wouldn't mind
fixing it "the right way".
thanks in advance!
John
www.kayakfishingpro.com
thanks in advance!
John
