Is it possible to jump start a boat by pulling it threw the water?
amanphoto
My question is? Is it possible to jump start a boat by pulling it threw the water? The thought came to me today when I was stuck with a dead battery in my car. If a car has a standard (manual) transmission, and if you can get it rolling with a little speed, you can pop the clutch with the car in gear to start it. I know there are no clutches to engage on a boat. The thinking is,
1. Can you put it in "gear", Key on
2. Pull if forward with another boat (I'm not sure of what speed you would need to travel.
3. Is there enough force against the propeller to turn over the engine and start the boat?
blairjbyrd
Re: Is it possible to jump start a boat by pulling it threw the water?
2= no
3= no
rbh
but yes to#1. :D
Lrider
Best post all week ;) :p :rolleyes:
solar7647
As long as you pop the clutch..:)
blairjbyrd
I guess you could get enough speed if you went down a waterfall:eek:
The question was is it possible. The answer is yes ....depends on the boat' I have jump started an engine by cruising through the water and Engaging the reduction gear to have the motor start.
It was coming down off turbines onto MDE's We called it trying to "Catch it on the Fly"
We are also talking about big propellers and a major amount of water cruising by.
But if you wanna get technical we didn't really jump start the boat. only the engine.
Huron Angler
Actually I think going up a waterfall would get the prop spinning faster:p
Going downstream works for OMC outboards, Mercs require more RPMs to do this successfully.:D
BTMCB
Wouldn't the tow vehicle sink?
smokeonthewater
I'm surprised to see this question again so soon.... and asked seriously this time lol..... sure it's possible.... I'd say that with most recreational boats it would take 350 to 400 mph.... of course you would need to be ready with the parking brake (anchor) to slow her down before exploding the engine since the prop will get ALOT more bite as soon as it starts turning
Man this is gawna hurt but I bet it'll set a new record on youtube:D
180shabah
...just make sure you buddies all have fins on before they start pushing...
GatorMike
Ensign
Nobody really knows the answer for an OMC because they always start on the first crank.
gonefishie
Was this a brainstorm or brain fart? :D:D
DuckHunterJon
My take would be you can only do it in cold water since it's denser and will provide more umph to turn the motor over!
Seriously - while it's technically feasable, it's not practically feasable - would require way more speed to generate the force required to turn over the motor.
Drowned Rat
You guys are funny! Small motors are actually very easy to "jump" start using this method, with very little speed, around 10mph. We used to start a 15hp Suzuki easily by simply lowering it into the water, in gear, while under sail. It would fire up instantly. Of course you could always just pull start it too. The OP never said what size engine he was talking about. :)
I'm going to have to agree here. I did it on my 15 evinrude getting towed in at about 20mph. I was having fuel pump issues and startled my friend who was towing me when I unhooked and passed him! I can say with 100% confidence that it is possible with smaller outboards.
smokeonthewater
kewl:D
ok now who wants to try it on a bigblock :cool:
mjgates
Carry a jump box and it's not an issue.
H20Rat
great if its the battery! Bad if it is the solenoid, starter, corroded connectors, etc...
