Uxboat
Thread starter- Joined
- Nov 14, 2006
- 75
I have a 1977 Mercury 500 {50 Hp} which I just replaced the the water pump in,however I have no flow at pee line. Want to double check with some one who has done this before,
one the shifter should be in forward before dropping lower unit right ?
two to get the water pipe back in the pump correct must the motor be vertical ?
Standing behind the motor the pee line is the black plastic hose on the right sticking out about a inch right ?
If I pull down on the steel tube that goes into the water pump to check it,will it go back up alright ? Should a person stick the tube in the pump housing first then lift the lower unit up ?
Sorry for all the questions the more posts and info I saw the harder the job became.
Thanks Mike
Thanks Mike
