choke question
bkelly46
If I put my hand over the carburator it fires right up. If you don't hand choke it it will not start. Any ideas on how to make the choke work.
Frank Acampora
Re: choke question
Let's see? Is it an Evinrude? A Mercury? Suzuki? Yamaha? Honda?
Oh, no! It is on this forum so it must be a Chrysler, Force or possibly a West Bend.
Come on people--we are not mind readers and the various engines had different methods of enriching for starting. Help us to help you.
Sorry to be "cranky" or "snotty", but it is late and I don't get much sleep.
notsunkyet
Re: choke question
well first off what kind of engine? year model? if its a force 85 there is a green wire on the passenger side the powers the choke solinoid.... but we kinda need to know what ya before anyone can answer ya to help
bkelly46
Re: choke question
Sorry about that. 2000 40horse force is the boat motor.
roscoe
Re: choke question
Hi bkelly.
Your motor does not have a conventional choke, it has a fuel enrichment valve, or primer valve.
When you push the key in, it will open the valve and dump extra fuel behind the carb, into the manifold.
Starting procedure:
Open fuel tank vent
Check the kill switch, place in "run" position
Squeeze fuel primer bulb till firm.
Advance the throttle 3/4 way, without putting it in gear. -- This is done by either pushing a button in the center of the controls, or pulling the shift handle toward the driver, or raising the fast idle lever, all depending on what control unit you have.
Activate the choke (fuel enrichment valve) by pushing in on the key. The valve is only open while the key is being pushed in.
Turn the key to start while continuing to hold the key in.
Release the key and choke when it starts.
3-5 seconds of "choke", is usually enough.
Be ready to pull the throttle back toward the idle/neutral position, when the engine starts and the revs increase.
Continue to pull the throttle back as the engine warms up.
You should not have to use the choke much, if at all, once the engine has warmed up.
Engine should start within 10 seconds of turning the key.
And one more thing, the last production year for Force motors was 1999, so your motor is likely a 99, not a 2000.
Post the serial number and we can check.
