Tommywalton
- Joined
- Apr 23, 2010
- 170
I'm finding more and more things wrong with my 275 drive. You guys have helped me through a lot. I've replaced u joints, bellows, orings, water neck to fix some problems. I've traced my air intrusion/overheating problem to the water neck gasket and possibly the bottom o-ring sealing the yoke to the lower gear box. My question is I have found about 1/8" play in the intermediate housing. Only up and down play no side to side. This small amount of play allows the yoke to turn inside of the bushings. Is this normal? I'm installing new lower gearbox o-rings tomorrow. My concern is over time this rotating yoke will wear out or cut the o-ring possibly allowing air into the raw water inlet.
Any suggestions will be appreciated.
Thanks
Thanks
