Whos changed there own blower before and how long did it take you?
dkorzun21
How long has it taking you to change your blower? If just the blower is bad and not the wire or the switch.
And if the wire or switch are bad?
Mine broke and I need to get this down before tommorw night hopen it takes under a hour and my blower or a new one will be up and running.
smokeonthewater
Re: Whos changed there own blower before and how long did it take you?
on my boat 4 screws 4 clamps and 4 wire connections..... did 2 blowers in under 15 minutes
a70eliminator
It would take my more time just to get at the blower than to pull it. A couple screws and two hose clamps, but first need to remove the engine cover rear seats batteries, so at least an hour for me.
ftl900
Nothing tough about it other than location. Took me about 20 minutes.
cpubud
20 minutes to get all the tools together and to get to it then 10-15 minutes to change out
25thmustang
Mine came out in 5 minutes tops. Waiting on the new ones.
fat fanny
No lomger than it takes to make a pot pf coffee that is if my son hasn't been into my tool box again!!!!!!!!!!!!!!!
180shabah
If you can get to it, probably one of the easiest things you'll ever fix on a boat.
