Re: 1974 115 evinrude quits after 15 minutes
first ,you def need to find out if water is pumping through,dont wont to burn it up,,,,if it has been quitting due to overheating,the damage may already be done,,,,i still suspect a fuel problem ,,,,,,,,,if it is pumping water,and you run it till it quits again,check the spark as soon as it dies ,make sure there is fire all around,,,,,,,,,,if you dont have a manual and youre going to try to keep this thing happy with your own skills,i would suggest a manual,,it made my life alot easier,theyre avail here on iboats reasonably priced
