1984 mercruiser 260 misses at WOT
thsorens
some history first. I replaced the motor about 4 years ago. At that time I put all new wires, plugs, distributor cap and rotor in. It has been running flawlessly every since until.... Last weekend (the first time I really ran it this year) I sprung a leak in the recirculating pump. The kids noticed it cause there was warm water in the cuddy, just to give you an idea of how much water was leaking. The water came out of the circulating pump, hit the belts and sprayed everywhere. Also that day, my choke stuck on and was obviously running very rich. While limping it back to the dock I started to notice a miss at idle. This week I replaced the circulating pump and the choke. Took it out and had an intermittant miss when really getting into the throttle and at WOT. I replaced the plugs, thinking I may have fouled one due to the choke being on all day. That seemed to clean up the miss at every RPM except for WOT. I still have plenty of power and can get to 4800rpm like always, but once there, it starts missing and maybe even popping. I described it to the local marina mechanic and he thinks its my thunderbolt IV ignition amplifier. Those things are like $350! I suppose I should try the coil and cap first, but I hate to just throw money at it. i found a troubleshooting test for the ignition, but it assumes you have no spark at all. I'm just wondering if the warm engine spray over the motor steamed the cap or fried the spark box.
Any ideas?
Thanks
Tom
Re: 1984 mercruiser 260 misses at WOT
Ayuh,... I'd start with the fuel Fliters,... I'm betting it's goin' Lean at wot...
thsorens
Nope already tried fuel filters, definately ignition related.
jtmarten
There are a few sellers on ebay with reasonable amps. Pull it and see if its full of water. If so, you may be able to let it dry and hope it fixes the miss.
thsorens
I have a voltage problem apparently. Last night I discovered that while running at WOT if I turn on some accessories, the blower, captains calls, bilge, stereo amp, trim the outdrive, whatever. The tach starts bouncing erratically and the motor starts cutting out. Shut everything back off and it runs smooth. At idle my alternator shows 14v at the battery. with engine off and the key on I show 12 volts at the coil. I'm going to clean all my connections and maybe even replace my alternator. That thing never has charged that great since I've owned the boat. Could a weak coil also be affected by turning on accessories like that? Also I have a 2 battery system and have tried it on each battery individually with the same results. Getting closer..........
thsorens
took apart and cleaned all my electrical connections at the coil, distributer, main electrical plug on engine and replaced the coil. Runs like a banshee again. Not sure if it was the connections or the coil but either way, its fixed.
