454 crusader inboard overheating help needed
JohnnyBuoy
I have 1995 2600 Pursuit, with an inboard 454 Crusader freshwater-cooled engine. I have tried everything and it continues to over heat. This is what I have done.
1. Cleaned heat exchanger, extensively
2. Replaced raw water impeller and pump
3. Replaced risers
4. Replace thermostat
5. Pulled freshwater pump and checked extensively
6. Checked clam shell on thru-hul
7. Ran with thermostat AND without thermostat
8. Flushed oil cooler
After doing all of this it continues to overheat. PLEASE LOOKING FOR SUGGESTIONS!!!!:confused::confused::confused:
Hansolo99
Re: 454 crusader inboard overheating help needed
Does it do this on Muffs and on the Lake??
JohnnyBuoy
I'm sorry I am not sure what you are asking me...
Hansolo99
Is there a water supply when you are running it?? Is it hooked to the hose or at a lake??
Bt Doctur
leaking head gasket more than likely.Compression test and leakdown test may isolate it.
JohnnyBuoy
It is docked in saltwater...
