bramiller310
Thread starter- Joined
- Mar 31, 2010
- 10
I replaced the spark plugs on my motor the other day and now it just turns over and will not start. Checked the spark and it is good on all 3 cylinders. So I figured it wasnt getting fuel cause you can spray fluid in the carbs and it will start for about 2 seconds and die and the bulb is still hard. So I started disconnecting fuel lines and pumping the bulb to see if I had obstructions any where. I pulled the lines all the way to the first carb and it is making it there but is it possible that the clog is in the needle valve or seat? That is the only thing that I can think of at this point. If you have any other troubleshooting ideas send them my way please.
