1978 Evinrude 115 RC stuck in forward
uscdynasty
My shifter is stuck in forward, wont go into neutral and therefore unable to start motor, unable to shift into neutral or reverse, it goes to the neutral setting but I dont hear the click and the key wont work, what gives? thanks in advance. The motor was running and shifting fine, when I was going to pull the boat onto the trailer the shifter kinda got stuck and I forced it, now its stuck.
floatinggenius
Re: 1978 Evinrude 115 RC stuck in forward
Just a thought for you. Evinrude documentation and sources are plentiful on the internet. Try this site. You can find literature about each part.
http://www.pdfgeni.com/book/Evinrude-115-pdf.html
If you can't find it there, I have a question for you. Does your throttle have a lever for the gearing below the throttle handle? If so, then I you probably need to fix the lever.
If not, I believe its a cable issue. Those things go back and forth so many times in a lifetime, they may come loose or tighten till they tweak and break.
Evenrude also has a site dedicated to its past. Google Evenrude literature.
My Blog:
http://thirdcoastyachtsales.blogspot.com/
Joe-jo
Welcome to iboats! But I agree it sounds like its in your cable or shifter itself.
uscdynasty
thanks guys, no it doesnt have the gearing underneath, I'm taking it apart to see whats up I apreciate the help.
wilde1j
Disconnect shift cable at motor and try to shift (while spinning prop) manually. If you can, the problem is with the cable and/or the control unit.
kenmyfam
Agree with the above post ^^^^^
