Re: I'm an owner! 1975 Islander 22
Can't believe I forgot to bring the camera today. My sincerest apologies.
Got the transom wood out today using Jas' method with the strap slid between the aluminum and wood, through the big hole and back up. Hooked that to the chain hoist on my skyscraper gantry and started pulling. Came right out, easy peasy. The wood has extensive rot throughout, so I'm really glad I decided to go through this hassle. The good news is that it all came out in one piece (even the bottom) so it'll make a great template. The aluminum part of the transom looks like it'll clean up nicely. I didn't see any corrosion, but I still have to clean it off to fully inspect it.
Took the seat box off the the starboard tank and found the source of the fuel smell. The vinyl and wood underneath the tank were wet with gas, so this tank definitely has some small leaks. The tank was still full after five years, so the leaks must be very small, but there nonetheless. Once I get it all siphoned out I'll get to cleaning it up and inspecting it. Is JB Weld a good idea or a bad idea for patching fuel tanks? Would I have to do it from the inside too?
Pulled the side board and found more chewed foam and a much more extensive squirrel nest. Like sticks, leaves, pine needles and fur. Then upon closer inspection, the fur turned out to be the mummy of an actual squirrel that looked like it had been there for a couple generations.
I could not for the life of me figure out how to get the controls removed from the sideboard. I got the handle (and what I assume is the choke knob) off and removed three screws on the round backing plate, but nothing would come loose beyond that so I just disconnected the cables and left the control attached to the board. If anyone knows how to get this one loose, please speak freely. Again, I apologize for the lack of pictures, this one's kinda hard to explain without them.
Also pulled the new motor back out so I have more room to work and start pulling the floor out.
Then I realized it's August already. Wow I have a long way to go.
