89 johnson gt 150 v6
idotxdermy2
my engine will idle fine, will cruise at a low speed greatly, but when i go to put the foot down it bogs like its getting too much fuel and smells like its flooding....what would cause this?
ezeke
Re: 89 johnson gt 150 v6
Probably is getting too much gas; you might try replacing the high speed jets. First make sure that the throttle plates are perfectly synchronized. The plates should all be perfectly horizontal at WOT and move precisely the same as you move the control arm.
ezeke
Wide open throttle. The throttle plates allow maximum flow in the perfectly horizontal position.
