andyman2010
- Joined
- Apr 18, 2010
- 22
Hey everyone,
Cruising across the lake last night full speed suddenly the motor lost its thrust but was still running fine. Its like it slipped into neutral. At very low speed it will run and move across the water slowly, but when I give it throttle it winds up as its not in gear. Let it idle back down and it will move.. albeit slowly.
It has the Forward Neutral Reverse shifter and I was hoping for pointers before I start to tear into her.
I rotated the prop by hand and can hear some nasty grinding in the prop housing so I am assuming clutch dog/gears are shot. Any tips on replacing the clutch dog, or at least how to get to it. Do I need to remove the whole lower unit, or just the prop housing?
