Hi
I have read a few posts with sim problems but as yet have not seen anyone say they have found a fix.
Am hoping someone has!
I have recently bought a boat that has twin 115hp yam 4stroke 2003/04 models
When i bought the boat both tachs (faria combo's) were not working (factory fitted by boat builder)- i bought 2 new faria gauges and the still dont work.
They are wired to the green wire from ignition, when motors are turning over there is a signal coming thru (tach go up to around 750rpm) when the motor fires and idles the needle drops down to zero and just flickers slightly.
Unlikely that two faulty tach and two broken/faulty signal wires!! - but then i guess stranger things have happened.
I have installed two of trim and volt meter and one fuel gauge - all stem from the same power source (yellow wire from ignition) and all work fine -tachs are wired in with these gauges -have wired tachs seperately and still no difference....
Any ideas welcome
many thanks
Bill
Any ideas welcome
many thanks
Bill
