Re: 1995 J200 stalls above idle
-Primer bulb was mushy, so that was replaced today..
-Could not start the motor. There was no spark when viewed with the tester. Pushed the kill switch in and out a few times and the motor started. Local dealer did not have a kill switch, but found one nearby will replace tomorrow..
-All ignition coils were in spec when checked with an ohm meter, ~275 ohms.
-Timer base resistance from port D and starboard D pins was in spec, ~230 ohms.
-Timer base pins D to A,B,C (both port and starboard) read high at about 220k ohms, but were consistent to each other. Think the timer base is toast?
-Have a volt meter, but need a DVA peak voltage adapter. Looks like an analog meter at better for these checks, huh?
-Did I test the sparks right? I removed all of the wires from the six plugs, connected the clip (see pic) to the a plug terminal and other side to the ignition coil, then cranked the motor. It was bright day, but I saw at thin line of spark. Was not very bright in the daylight sun, but was there. If this is the right way to test will test all plugs tomorrow.
-The butterflies are closed at idle and are at 90degs at full throttle.
-Tried after the above.. Motor ran fine out of the marina, but then had problems above idle, but would run well past 2k rpm. And then it kept stalling at idle. Finally got it started and limped home.
-Will test spark on all plugs and replace kill switch tomorrow. Also picked up remote cables because the current ones are old and sloppy.
-Linkage does not appear to be binding anywhere.. Thanks..
