silver_power
Thread starter- Joined
- Jul 8, 2009
- 334
Re: Low engine power during break-in period?
Ok my friend,.....I will!
What do you mean with this?Also consider the boat itself. That will make a difference.
Your 11.5hr MPI isn't making 300hp at the prop YET. It may need an additional 10-20hrs of run time to fully break-in,
So i do not think that there is no diffenrence before and after break-in!
Basically engines just "loosen up" during their first hours of life - some more/quicker than others.
The only engines that need break in these days, are real racing motors with nikasil sleeves in rocketbike engines. Now you do have to temper those in or you'll glaze them out. Everything else you can just run.
And if you don't believe me... then tell me specifically what measurment in the engine building process changes.
I'm not compelled to remotely fulfill your fantasy of instigating more keyboard pi$$ing contests..
Pull just an owners manual for just about any 2010 automobile. There are no "break in" instructions in those anymore.
After proper "running in" the honed surface and ring face tends to obtain a smoother finish and hence less friction.
Any extreme loading of the engine during the "bedding in" process can and does lead to what is called micro seizure and has detrimental effects on the engine.
