Re: 1979 johnson 85 hp Javelin
Weak ignition components tend to fail when the engine heats up to normal operating temps. The ignition system has a stator, timer base, power pack and coils-any of which could break down with age. They are all fairly expensive, so an investment in some testing is worth your while. An inductive timing light put on each plugwire will show flashes. These flashes will show any weak firing, intermittent or even no firings. It can lead to finding the culprit component. Also, this model has two power packs and four coils, all of which can be swapped around to help discover a defective component. A factory manual is a worthwhile investment, as it has a number of electrical test procedures. You can get an original from Ken Cook Co., in Milwaukee. You can see the parts lists for this engine on the web at: epc.brp.com
