Will not idle! Comps 125 both.
Carbs have been cleaned twice with both Carb cleaner kit and my Ultrasonic tank. Same process I have used many times. New kits.
Good strong sparks on the tester.
Replaced the VRO, which I thought defective, with a new standard pump. Getting plenty of fuel up
Have done the sync and tried various settings. There is no base Timing setting in my manual but it fires best at about 1to 2 after tdc. Will fire but will not start without bringing up the throttle and timing mechanism. Will not continue to run without holding up the throttle and timing on the lever mechanism. Runs lumpy, then relax the mechanism and she dies.
Running on my stand in the tub. Same symptoms that caused me to change the pump.
Got me stumped. Any ideas guys?
