I am new to this forum and after searching the internet came to this site and you all seem to be knowledgable so I am hoping you can help me.
I have a 175hp Mercury I believe it is a 1989, I had it out this weekend and for some reason when I turn the key it clicks. I remove the cover and watch the starter, the pinion gear does engage with the flywheel but it doesnt seem to spin it fast enough its a very slow spin and after a couple times of spinning it just holds fast.
I wondering if I need a new starter, maybe its possible that its a connection issue, I took the pinion gear off and I'm not familar with these things so I don't know if there is something inside of that that could be bad. The battery was tested and had 12.5 volts so I don't believe its lack of battery power.
Any info you guys could give me on what to check or replace would be great. Thanks in advance.
